327 (5.3) to replace 305
Old Jan 21, 2008 | 10:25 AM
adampgasser's Avatar
Member
Default 327 (5.3) to replace 305
I've currently got a 305 in my 1998 k1500, and with 178,000 it is getting worn. A buddy has a rebuilt 327 will that work in my truck? Will it bolt in alright?
Old Jan 21, 2008 | 12:32 PM
rxsteven's Avatar
Default RE: 327 (5.3) to replace 305
Its the same block I dont know about the ECU but the block should bolt right up.
Old Jan 21, 2008 | 01:55 PM
jcbst12's Avatar
If the 5.3 was rebuilt and it worked/ran correctly afterwards, than you'll be ok. I would toss all the old EFI stuff from your 5.0 and use 5.3 sensors, PCM, wiring, etc. Unless you are using just the 5.3 block without the intake, fuel system and heads and using the ones from your 5.0, then you'll need a custom tune for the engine to comp for the difference in ci. Everything should bolt from the 5.0 to the 5.3 but Im not 100% on that.
Old Jan 22, 2008 | 05:03 AM
Argon's Avatar
you'll need it ALL...wiring,pcm,everything
bwracing00
Vehicles for Sale
Feb 8, 2011 08:50 AM
Regal105
13
Apr 9, 2007 04:26 AM
chevy4ever
Apr 8, 2007 09:33 PM
floridastatenolefan
Jun 26, 2006 01:09 PM
gmrules
May 24, 2006 01:02 AM
