4L60E sudden transmission leak?
Old Apr 17, 2012 | 05:13 PM
droptheone's Avatar
Default 4L60E sudden transmission leak?
Hey guys, I have a 1992 C1500 5.0L 107,000miles with a 4L60E
I've never had a transmission fluid leak, nor have I had to top it up and it's never shown weepage on the transmission anywhere.
So my truck was stolen a few weeks ago, and has now since been recovered. I was at the estimator's shop this morning and there was trans fluid leaking from the front of the tranny. Maybe 1/4 cup's worth.
If there's no signs of the tranny cracked anywhere, is it possible the seal could have broken under pressure or hard use?
Thank you
Old Apr 17, 2012 | 06:27 PM
chevychase's Avatar
Probably ran it hard joy riding shifting down gears ect.
But you do not have a 4l60e unless someone installed it.
Should have a 700r4 . 3/4 ton could get a 4l80e in 92.
Did not install 4l60e till 93.
Insurance should pay for it. Have them to rebuild it.
Old Apr 17, 2012 | 06:29 PM
GMC D-Max's Avatar
Sounds like it was rode hard, and put away wet!!
Front pump seal would be my guess. If it seems to leak more when it's running than when it's just sitting, then that's the culprit.
Old Apr 17, 2012 | 06:31 PM
GMC D-Max's Avatar
If it was a late '92 build, it's a possibility. Easy way to check: Look for a TV cable attached to the throttle body!
Old Apr 17, 2012 | 07:34 PM
droptheone's Avatar
You know what? you're right! It is a 700r4
Old Apr 20, 2012 | 12:12 PM
NullHead's Avatar
Yeah that'll be a 700r4 (4l60 minus the E, really). I imagine it's the input shaft/pump seal if it's leaking from the front of the trans. As long as the trans works, I imagine the seal could be replaced without a rebuild, but honestly I don't know.
Old Apr 21, 2012 | 12:12 PM
Diesel Dan's Avatar
Try to get the insurance to cover it.
If they don't at least it's a 2wd and easy to pull. Things I'd do if it was mine to fix is pull the pan to drain the fluid and look for clutch debri or metal particals in the bottom. Pull the trans, drain the converter, inspect converter hub for damage at bushing area, remove seal and visually inspect pump bushing. As long as the trans shifted good, TCC works and no issues in the pan go ahead and reseal and refill. While the trans is out replace the rear main seal on the engine.
PS: dont forget to replace the little o-ring on the pump shaft.
CraicHead
9
Oct 26, 2019 02:47 PM
Blair
Oct 25, 2009 03:55 PM
GMCTRUCKS
Aug 31, 2009 05:33 PM
gmworker
Aug 29, 2008 08:26 PM
rkr29kracing
Feb 18, 2008 03:03 PM
