4L80E problems
Old Oct 16, 2007 | 08:21 PM
JakeSilverado's Avatar
Default 4L80E problems
While i'm cruising down the freeway @ 60 MPH my motor usually turns about 2000 RPM's. Lately I look down and it is slowly creeping up to 3000RPM's, but when i barely touch the gas the RPM's drop back down to 2000. like it's slipping out of overdrive or something. I have 56K on the rig and it is a 4L80E 4X4 anything i sould try? computer problems, sensor? I really find it hard to beleive my tranny is going out already. Dosn't slip in any gears just kinda floats out of overdrive but goes back in when i tap the gas.
Old Oct 16, 2007 | 10:41 PM
racethisz71's Avatar
Default RE: 4L80E problems
it might be electrial hit the overdrive button next time this happens see if it down shifts also about that millage the fluid should be changed i would also do that
Old Oct 16, 2007 | 10:50 PM
I'm getting the fluid and filter changed this week. I don't have an overdrive button but I can downshift and see if it is already in 3rd or somewhere between 3rd and OD.
Old Oct 17, 2007 | 04:35 AM
Argon's Avatar
sounds like a converter lock up issue...i'd look for codes
Old Oct 17, 2007 | 07:38 AM
argon should i just go down to the dealer and have them read the codes, or does the autopart store code reader read tranny codes?
Old Oct 17, 2007 | 07:35 PM
Cracker's Avatar
Argon stole my thunder.
Old Oct 17, 2007 | 08:11 PM
Took it to the dealer today and they looked it over, hooked there scanner to it and found nothing.I had them drive with me and I couldn't get it to do it. I went back to work letting it sit for like 5 hours then drove home and it did it again untill it warmed up so tomorrow i'll drive it to the dealer and tell them to let it sit all day and thendrive it. the guy told me that the transmissions almost never fail but they sometimes have problems with the locking torque converters. We'll see. They better not charge me $81 again to look at it or
I'll park my truck on top of the service manager.
Old Oct 18, 2007 | 07:51 AM
jcbst12's Avatar
Change the fluid and filter first. If it still does it, then take it back to the dealer. I had my tranny flushed at 60K and the fluid was shot. It shifted better but it wasn't til I replace the filter just recently that it really smoothed out and shifted near perfect. I just feels like its putting more power to the pavement now.
Old Oct 19, 2007 | 06:40 AM
I'm going to change the filter and fluid next week, they said it smelled a little burnt. Taking the tranny pan offis going to make me want to put in a shift kit, I better let someone eles do the flush.
Old Jan 9, 2008 | 01:41 AM
rxsteven's Avatar
Mine is doing this did the flush work???
tryc
Aug 11, 2008 08:56 AM
tboz89
Jul 2, 2008 11:16 PM
banshman
Jun 5, 2008 05:42 PM
swampdog
May 8, 2008 11:49 AM
brianbgboy
Jul 4, 2006 12:04 AM
