4wd gearing?
Old Jan 1, 2007 | 09:41 PM
imbroke's Avatar
Default 4wd gearing?
I bought a 2003 crewcab silverado 2 weeks ago. The truck is perfect but the 4wd is horrible. I am no mechanic, but is seems as though the front wheels turn slower than the rear, so rather than the front end pulling around the turn it gets pushed straight ahead. Hopefully that makes sense. I have talked with a few freinds, etc who have had or heard of this same type of thing. IT is very dangerous onslick roads. What do I do??? thanks
Old Jan 1, 2007 | 11:45 PM
HemiKiller's Avatar
Default RE: 4wd gearing?
Look in your glove box and find the codes that start with G, I can check these to see if they put the right ratios in the box at least.
Old Jan 2, 2007 | 12:00 AM
imbroke's Avatar
GT4 G80 Is this what you needed?
Old Jan 2, 2007 | 12:08 AM
HemiKiller's Avatar
GT4 is 3:73 rear end, G80 is limited slip. There should be one more for the front end ratio.
Old Jan 2, 2007 | 12:27 AM
imbroke's Avatar
THose are the only ones Im seeing starting with G
Old Jan 2, 2007 | 12:36 AM
HemiKiller's Avatar
You can check the ratio by marking the tire and marking the drive shaft, turn the tire one rotation and see how many times the drive shaft revolves. Compare the front to the back, it is easier and safer if this is done with the vehicle on stands.
Old Jan 2, 2007 | 12:42 AM
imbroke's Avatar
thanks for the help, Ill have to get someone who knows what they are doing to help as I have no idea. thanks for your time. Suprised the code is not on there
Old Jan 2, 2007 | 12:49 AM
HemiKiller's Avatar
No problem, good luck and I hope you get it figured out.
Old Jan 2, 2007 | 12:45 PM
imbroke's Avatar
anyone else ever have this problem or dealt with the dealer on this?
cubpak89
Aug 19, 2011 02:50 PM
rtrvler
Jan 21, 2010 05:20 PM
esmiff
Feb 14, 2008 06:36 AM
motoguy
20
Feb 12, 2008 03:16 AM
pclosse
Aug 13, 2005 10:52 AM
