how to tell what gearing
Old Aug 18, 2011 | 09:09 PM
cubpak89's Avatar
Default how to tell what gearing
ok so how can i figure out what type of rear end gearin i have along with front the rpo code says its 3.42 in my daily driver
but i got the rear end from the 92 i am uusing as a donor truck and i want to see if its higher gearing if so its goin under my truck soon
i think if i count the ring gear and the spider and divide it into each other it should tell me
but if theres an easier way that would be good
3.73 is a good gear for towing if its that ill be one happy guy plus the rear end of the donor truck has 125xxx miles so it wont be as worn out as my daily driver axle
Old Aug 18, 2011 | 10:41 PM
red02's Avatar
Mark a spot on the axle and on the yoke. Spin either one and see how far the other moves. Also if your truck is 4wd remember the front and rear axle ratio's have to match.
Old Aug 19, 2011 | 09:23 AM
MrDragon's Avatar
Red nailed it with what he said and you're also right cub. Both ways will work.
Old Aug 19, 2011 | 09:24 AM
MrDragon's Avatar
Also, the 3.42 isn't a bad gear. Decent power, it'll pull ok but the key being fuel economy.
Old Aug 19, 2011 | 02:50 PM
cubpak89's Avatar
thanks i want to put it under my truck as it dont have near as many miles as my daily driver
ive tried sellin it so i think ill keep it around until i get around to putting under
rtrvler
Jan 21, 2010 05:20 PM
esmiff
Feb 14, 2008 06:36 AM
motoguy
20
Feb 12, 2008 03:16 AM
imbroke
8
Jan 2, 2007 12:45 PM
RICE FED
Dec 8, 2005 01:16 PM
