6.5 diesel help
Old Oct 20, 2007 | 09:21 PM
dieselnewbie's Avatar
Default 6.5 diesel help
I just bought a '96 3/4 ext cab 6.5l diesel. Engine, transmission and transfer case rebuilt; seems to run fine until I try to pull my fifth wheel (7400 lbs) and then it bogs down on every hill. MPG, wether I'm pulling the trailer or not is around 9mpg which seems low. I have taken it back to where I bought it and had it Sun tested and they said everything checks out. I've been told I should have no problem pulling this trailer. What could be wrong?
Old Oct 21, 2007 | 05:33 AM
Argon's Avatar
Default RE: 6.5 diesel help
open the T valve where you drain the water out of the fuel while its running...if nothing comes out,you have a lift pump problem....has the filter been changed?
quikscss
Nov 5, 2009 07:00 PM
cminzey
Jun 29, 2009 11:16 AM
Jack Bauer
Oct 13, 2008 03:52 PM
propaneman
Oct 29, 2007 10:07 PM
marine6132
May 2, 2007 12:31 AM
