88 chevy engine problems
Old Jun 4, 2010 | 05:33 PM
redneckhunter161's Avatar
Exclamation 88 chevy engine problems
so my truck idles just fine. you go to get on the gas and it maxes out at 2500 rpm's. the distributor (complete), plugs, wires, coil , fuel filter, and injectors filters, have all been replaced. any idea what could be wrong.?
Old Jun 5, 2010 | 06:40 PM
RUFFNECK4LYFE's Avatar
Not sure if it has one, but might check for a bad TPS.
Old Jun 6, 2010 | 01:56 PM
thanks for the reply. but what is a tps!?
Old Jun 6, 2010 | 03:13 PM
chrisbmo2000's Avatar
TPS = Throttle Position Sensor.......but how about your timing? is it right? or are you "180 degrees out"?
Old Jun 7, 2010 | 06:31 PM
seejgo2's Avatar
Member
i had a 1994 suburban 5.7 litre non-vortec not sure how close it was to yours but mine did the same thing got few more rpms then u but idle fine and it turned out to be the fuel pump. always thought they would just quit but nope. changed it and like a whole new truck. my 2 cents
Old Jun 10, 2010 | 04:57 PM
Default thanks
ok so we got it to idle fine and drive fine for about a mile. then it wouldn't break 1100 rpm's. took it to the mechanic. FUEL PUMP. thanks for the input. greatly appreciated
SANDYGEL
Jul 23, 2013 03:11 PM
johne623
Jan 16, 2011 05:13 PM
rfreidel
Oct 26, 2008 08:25 PM
Birddog
20
Mar 28, 2007 08:36 PM
SPRCHRGDGM
Jan 23, 2007 08:13 AM
