91 chevy popping,backfiring...
Old Jul 12, 2007 | 01:30 PM
ibleedchevy's Avatar
Default 91 chevy popping,backfiring...
Hello all I'm new to all this forum stuff, And I'm in DESPRATE need of help.I have a 99 Tahoe and a 91 Chevy shortwide, It has a 350 with power pulleys, power tower, a super chip, and dumped flowmasters.and i'm having trouble with it. It just started to cut out at shift points or higher rpms, the tach would jump from 1 to 2500 rpm and higher. I had the iginition module tested 4 times and it has come back good, I replaced the pickup coil,new cap and now it's running much worse than before (horrible) The timming is dead on and when the timming wire is unplugged it runs perfect but when I plug it back in and restart the truck it goes to crap, popping, backfiring and almost sounds like the motor is under a strain to run, I am usining a Snapon timming light and it shows the rpms jumping from 880 to 3900 all in between. I have even put the factory chip back in and it makes no difference! Can anyone please help me??? Thanks for any help you can give me.
Old Jul 12, 2007 | 02:25 PM
Argon's Avatar
Default RE: 91 chevy popping,backfiring...
usually...when the tach jumps its a sign of a coil...but distributors were crap in those too...
Old Jul 12, 2007 | 03:41 PM
is there any way of checking the distributor ?
Old Jul 13, 2007 | 11:48 AM
ok so on the distributor under the rotor there are to two sets of teeth that turn past each other.1 set is on the actual shaft and the other is mounted ontop of the pickup coil it has like 4 screws holding it down wich holds the pu coil in, now in between the pu coil and the teeth on top there is like a magnet spacer? andmine is broke... could this cause a problem?
Old Jul 13, 2007 | 03:49 PM
stopspazinout's Avatar
yea, those usually wear out and cause, that but in your case i guess break, so gonna need a new one
Old Jul 15, 2007 | 06:05 AM
so do u know what the part is actually called?
Old Jul 15, 2007 | 05:46 PM
pretty sure it only comes with a new or reman distributor. but if its that bad why not replace it so its firing right?
ridex3
Feb 23, 2012 04:48 PM
newchevyowner
Jul 18, 2010 06:24 PM
akeramidis
Jan 18, 2008 02:32 AM
nakins
Jun 5, 2007 06:15 AM
DustyR
Sep 25, 2005 12:51 AM
