91 Fuel Injection Issue - I think
Old Oct 18, 2009 | 09:48 PM
  #21
Six5's Avatar
OK, I got distracted with another project. Sorry for the interruption.
Now that I'm again investigating my FI problem, I have satisfied myself that the issue is not the MAP sensor. At the MAP sensor connector, the +5 volts and Ground are present, and when I apply vacuum to the sensor the center output contact swings from +4.6 volts to +0.7 volts. I also traced the continuity of the sensor's output conductor back to the ECU. It was good and didn't show any intermittent behavior.
Now, since the general opinion is leaning toward a vacuum leak, is there any benefit in measuring the manifold vacuum? If I had a vacuum gage, are there any meaningful readings I can take that might point me in the right direction? Where would I connect the gage? What values should I expect to see?
The PCV valve has been eliminated, so it is not the source of a leak.
Old Nov 28, 2009 | 05:19 PM
  #22
Six5's Avatar
Thumbs up
I'm resurrecting this thread merely to bring it to a logical conclusion. For those of you who had the interest (or fortitude) to read through it, you'll be happy to know that the root cause of my idle problems was a tired fuel pump. For those of you who helped me figure that out, thank you very much.
Actually, I owe Ruffneck an apology of sorts because he suggested early on to check the fuel pressure, but I figured since the engine would start and run (though with difficulty) that it couldn't be the fuel pump. I could SEE that the engine was getting fuel. True it was getting fuel, but the pressure was too low. Well, I have now been educated thanks to you. Had I listened to you then, I could have saved myself much time and money.
In a nut shell then, if your truck begins to suddenly idle strange and it won't take throttle, be sure to verify that the fuel pressure is correct before you waste a lot of time and $$$ looking elsewhere.
Cheers
bctarver4
Nov 16, 2008 11:24 AM
JLusive425
May 13, 2008 01:55 AM
smurphy4211
Apr 14, 2008 05:22 PM
speedo45
May 20, 2007 11:02 PM
jdhorton00
Oct 16, 2006 09:20 PM
