92 chev heater fan problem
Hey guys have a prob with my truck.
92 chev 1/2 ton ext cab v8 2wd Heater fan works great got cold air and warm air but the window vents have no air flow. Floor and dash work great. When i set to window i get a whistling sound and no air flow and with winter here it sucks. What could the prob be and what kind of parts with i need to fix it? I have a haynes manual and can figure out pretty much anything with a little direction. Thanks! |
Cable or door problem with your heater box.
Right on will tear er apart and check them thanks
Thankfully for you, the heater boxes on these older Silverados are pretty easy to work on ;)
Good luck, and let us know what went wrong when you figure it out. |
Sounds like you have a stuck door. The fan position selector motor is just to the right of your right leg when sitting in the drivers seat. There is a little motor down there on the side of the air plenum that moves the blend doors around. I would start by removing the motor (3 brass colored 7/32nds) and moving the doors manually. Sometimes they can stick, especially if they aren't used in that position a lot.
