-   -   92' GMC thermostat problems (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/92-gmc-thermostat-problems-18341/)
Harland Feb 17, 2012 05:15 PM
My thermostat needle does not budge (literary, turn it on and off does not move). Any suggestions on what it could be?
Its a Sierra.
Mr_Shamrock Feb 17, 2012 07:32 PM
The sensor for the gauge is on the drivers side of the block and has a single wire going to it. Make sure it is plugged in and if so, try grounding the wire to see if it makes the gauge move. If it still doesn't move than the guage itself is bad or you have a broken spot in the wire somewhere.
Harland Feb 17, 2012 07:45 PM
mhmmm. Me and my Dad took a look under the hood and there is one wire not plugged into anything. When I change the air filter tomorrow I'll post some pics.
Correction, heat gauge not thermostat
Harland Feb 19, 2012 11:05 AM
1 Attachment(s)
Here is a image of the wire.
NullHead Feb 19, 2012 09:26 PM
Hmm I have no clue what that wire is. Doesn't look like anything that's on my truck. Maybe the A/C compressor clutch wires?
Harland Feb 22, 2012 10:52 AM
mhmmm. Thinking the engine might not be stock....so any one know what the heat gauge issue could be?
Mr_Shamrock Feb 22, 2012 01:08 PM
Did you check the sensor on the drivers side of the engine?
Harland Feb 24, 2012 02:27 PM
Nope, is there a way to check it digitally or would it have to be done manually?
