92 Siverado HVAC control head dead??
Old Jun 2, 2009 | 03:57 PM
impac41's Avatar
Default 92 Siverado HVAC control head dead??
Howdy all you Heroes,
Backing out of a parking spot, reached up and pushed the fan (blower motor) button, and the control head went dead, lights out, no effect. Now there is no display, and no buttons work anything.
Hvac fuse (25 amp) is good, replaced with a new one anyway, no effect.
Disconnected the battery for a bit, no effect.
What else should I check?
Thanks, Mark
Old Jun 2, 2009 | 05:54 PM
timber74wolf's Avatar
Try checking your fuses or you just got a dead head unit.
Old Jun 2, 2009 | 06:00 PM
RUFFNECK4LYFE's Avatar
Get a test light and check for juice to the source. If you have power then its a bad head.
Old Jun 3, 2009 | 04:42 PM
impac41's Avatar
Default 92 Silverado hvac control dead
Thanks, Mark
Howdy,
Getting 12+ volts to the fuse, read varying voltages at the wiring plug: 8+ volts here, 5+ volts there... Is there another fuse, relay, or fuseable link somewhere?
I'd hate to buy another control only to find a problem elsewhere-
Thanks, Mark
Old Jun 3, 2009 | 06:23 PM
It might also have a relay. Check that. Switch it out with another one and see.
Mrjeff62
Oct 9, 2014 11:48 AM
vcolper
May 18, 2012 08:33 AM
bluiewest1
Jul 8, 2009 08:48 AM
reuse2recycle
Jul 9, 2008 09:42 PM
Regal105
May 23, 2007 04:27 PM
