94 gmc dies in heat every 5-10 miles
Old Jul 10, 2017 | 09:04 AM
Lowrunner's Avatar
Default 94 gmc dies in heat every 5-10 miles
I have a 94 GMC 1500 pickup truck with a 350 engine automatic transmission four wheel drive while driving in hot temperature about 90 to 95 degrees my truck all of a sudden died on me when I pull over and turn it off it'll start back up then I can run another 10 miles or so then it'll die on me keep doing that I would always have to pull over turn the key off wait for about a minute then start it back up and then I could drive another 5 to 10 miles no check engine light flashing engine temperature was at 195 what would cause that I thought maybe a vapor lock I undid the fuel cap but I didn't leave it Loose I just opened it up and screwed it back on tight but it kept doing the same thing I've never had this happen before thank you for your time and to anyone that wants to put in their two cents worth I'm not sure if it's a fuel issue with bad gas because I just filled it up or some type of electrical issue to a sensor or something
Old Jul 24, 2017 | 07:55 PM
Kris Surber's Avatar
You should try flushing your radiator. That can do wonders for a vehicle!
Old Jul 28, 2017 | 09:10 PM
Lowrunner's Avatar
or maybe sweep the bed out, right?
you obviously didn't read my post
Old Jul 28, 2017 | 09:11 PM
Lowrunner's Avatar
no heat issues
Old Aug 7, 2017 | 08:14 PM
NullHead's Avatar
Have your ignition control module tested at your local auto parts store. Sounds like a possible culprit
Old Aug 17, 2017 | 12:33 AM
steamnjn23's Avatar
I had the same problem with my truck. I replaced the fuel pump relay and the problem went away.
hydro3
Apr 2, 2013 03:10 PM
eryka
Oct 6, 2010 06:56 AM
MIBPreacher
Nov 19, 2007 06:00 PM
majordad
Nov 4, 2007 12:37 AM
general z
Aug 1, 2006 05:58 PM
