94 GMC Sierra not running right, need help
Old Dec 31, 2013 | 04:59 PM
eviltouch89's Avatar
Default 94 GMC Sierra not running right, need help
I cant figure out whats wrong with my truck, I have to pump gas to start it, sometimes it idles bad, it spudders while driving, hesitates and rpms drop when i punch the gas stalls out when stoped, seems to be worse the colder it is outside. Ive changed fuel filter, spark plugs and wires, distributer cap and roter. any ideas I dont know what to do next.
Old Dec 31, 2013 | 08:36 PM
NullHead's Avatar
Check for a vacuum leak at the base of your throttle body by spraying carburetor cleaner around the base. If the RPM changes when you spray the cleaner there, then you've got yourself a vacuum leak!
Have you checked your fuel pressure?
Old Jan 1, 2014 | 11:19 AM
someone checked my vacuum for me and told me that there was no leak.
no i havent checked the fuel pressure.
And i forgot to mention when I bought the truck it was sitting for about 2 years
Old Jan 1, 2014 | 07:41 PM
poncho62's Avatar
Have you put new gas in it yet and run it for a while?
TB may be plugged up from sitting and need cleaning/rebuilding
Old Jan 1, 2014 | 07:50 PM
NullHead's Avatar
Yeah you could very likely have bad gas in there ... gas can go bad after just one year. Plugged fuel filter perhaps too.
Old Jan 1, 2014 | 08:08 PM
Ive had it for about 6 months now, changed the fuel filter 2x.
Could the fuel pump get cloged up from sitting?
there were times the truck would run great, then all of a sudden back to crap again.
Old Jan 1, 2014 | 08:39 PM
NullHead's Avatar
Yeah definitely check fuel pressure, also is your check engine light on at all?
Old Jan 1, 2014 | 08:53 PM
It must be a fuel supply issue... If it won't start unless you pump the throttle? And it runs good periodically.... This could be a sign the fuel pump is on it's way out, or the fuel pickup is beginning to plug with slug or rust.
There is possibly a fuel filter under your truck on the frame rail and a smaller one at the throttle body.
Another possibility is the two injectors are beginning to clog
Old Jan 2, 2014 | 12:32 AM
ya, the check engine light comes on randomly
Old Jan 2, 2014 | 04:10 AM
poncho62's Avatar
Scanning the codes wouldnt hurt
