97 sierra 3500 speedo/shifting problem
Old Dec 29, 2008 | 07:18 AM
troc's Avatar
Default 97 sierra 3500 speedo/shifting problem
Hello guys
I have a 1997 gmc sierra 3500/454/4l80e. It has started shifting erratically and also has not been indicating speed correctly. torque converter lock up is cycling. I changed trans filter/change fluid. Scanned for codes, no powertrain codes up. I jacked up truck and ran up to speed speedometer still not indicating correctly. I put DVM on transfer casespeed switch and it appeared to read correctly
ac voltage increased with wheel speed about 600 mv@ 45 mph. I have nothing to compare that to,also my manual shows two VSS, one also on transmission but the component I think is it has different color wiring . Anyone know what /where that sensor is? thanks in advance Cort
Old Jan 3, 2009 | 08:04 PM
troc's Avatar
Default RE: 97 sierra 3500 speedo/shifting problem
well I replaced both vss and still no fix. no codes up but still ****ting all over the place and speedo still not right. I am thinking PCM any ideas ...any one. Come on throw something out there thanks cort
Old Jan 3, 2009 | 08:59 PM
Chevyalltheway's Avatar
try posting in the chevy silverado area, there are more guys that browse over there
Old Jan 6, 2009 | 02:48 PM
troc's Avatar
thank you !
silvercav
Mar 11, 2010 11:08 AM
troc
Jan 6, 2009 03:27 PM
teri7
Nov 25, 2007 01:14 AM
drhino
May 4, 2006 03:24 PM
KOBRA2
Mar 7, 2006 10:48 PM
