99 1500 4.8L 97k- need help with clunk issue
Old Nov 6, 2007 | 11:12 PM
shaderz's Avatar
Default 99 1500 4.8L 97k- need help with clunk issue
when i come to a complete stop i get a little clunk almost like its a brake issue. but sometimes after i've stopped as soon as i release the brakes it feels like it slams into gear,but only first. no other gears shift hard. any suggestions or more info needed?
Old Nov 7, 2007 | 04:36 AM
Tweaker's Avatar
Default RE: 99 1500 4.8L 97k- need help with clunk issue
Id say check your rear end fluid just to make sure nothing is going on. Have you done a tranny service yet and changed/greased your axel U-Joints unless they are sealed?
Old Nov 7, 2007 | 05:34 AM
keithp's Avatar
I had a 89 Silverado with the same symptoms...Drove me nuts...It wasn't until an excellent GM Tech found that when you stopped, the rear driveshaft yolk would actually get forced into the rearend and actually stick.......let the brakes off and it would release with a "clunk or thud".....Maybe this is your clunk.......Let me know how you make out....
Old Nov 8, 2007 | 04:38 PM
HSV_Madman's Avatar
I have a '99Z-71 that does the exact same thing (101,000 miles). I know this is a common issue with these trucks but I would love to hear some more ideas about how to eliminate or reduce it.
Old Nov 9, 2007 | 04:05 PM
racethisz71's Avatar
i dont know how loud your clunk is but my u joint went and it was making a cluck when the tires stoped and started
Old Nov 9, 2007 | 04:32 PM
jcbst12's Avatar
Mine just does it when putting it into reverse, greasing the slip yoke helped a little. Will prob help you guys to do this.
Old Nov 10, 2007 | 12:22 AM
shaderz's Avatar
no tranny service yet, i'm not experienced enough to know what the rear driveshaft yolk is but i tried to get a feel if it was forcing into the rear end. the thing is it does not do this all the time. mostly in the morning and especially when the idle rpms are high. it also feels like when i let off the brakes they should release smoothly but they open up with little resistence.
sounds like this is something im going to have to take to the shop to fix?
kennyp516
Vehicles for Sale
Nov 9, 2008 03:07 AM
jeff460
Nov 18, 2006 04:03 PM
2000_z71
Aug 12, 2006 11:40 PM
GTRMN101
Jul 21, 2006 04:59 PM
fearless_fb
Jul 16, 2005 12:52 PM
