ABS Question
I have a 00 Silverado. When stopping at low speeds the ABS kicks on. I know this is a problem with either a bad or dirty sensor. I have also read that you can pull the ABS fuse to eliminate this until it is fixed. If you pull the fuse will the brake light come on and stay on until it is fixed? Currently the brake light is not on.
Thanks
Thanks
