Abs sensor problem
I recently replaced my hubs and rotors and they came with a new sensor as well. Replaced both fronts. Now the abs for the front left comes on and sometimes makes them do the abs pulse. I checked the exciter teeth they seemed fine. I do not know what else to do. Is there a reset or anything? Any help would be greatly appreciated. It seems like when I go down hill and apply the brakes it feels like they are bouncing. Any Clues?
try looking here https://www.truckforums.com/forum/sh...ad.php?t=11063. i had the same problem i never did try anything or figure it out so i unplugged the big fuse under the hood for the abs and it stopped. i have good brakes again but i need to read up and fix it right.
Have you checked to make sure you didn't pinch, stretch, or otherwise damage the wire on that side? Also make sure you didn't damage the plug or bend over a contact when you plugged it in.
chrisbmo2000
12
Feb 14, 2009 05:27 PM
