AC fan motor problem
Old Jun 14, 2007 | 05:16 AM
  #11
Argon's Avatar
Default RE: AC fan motor problem
yes,your pix are good..
the 05's was when we began seeing this a lot...i'm not sure just when the new part came out...maybe a year ago...it seems to have fixed the problem.
get a price on the connector yet?
Old Jun 14, 2007 | 10:13 PM
  #12
Sinjin1952's Avatar
Member
Hey Argon:
I haven't been able to get by a dealer to get pricesyet, maybe this weekend. (probably too scared!!!!)
Since my max position 5 burned out, did that speed go through a resistor? Usually the top speed is full power, resistors only step down the lower speeds?
Also, since the connector is part of the fixed wiring harness, the old connector must have to be chopped out and the new connector spliced in, hence your mention of needing a mini-torch for the shrink wrap on the wires.
Want you to know I sure appreciate your help in describing all this.
I only drive the Silveradoon weekends (mileage & all) during the week I drive a '89 Firebird/2.8 litre V6/Stick to work, gets 30 mpg at 68 mph on open road. I drive it to work to save the newer truck and benefit from the mileage.
Thanks & Regards,
Randy, Las Vegas
Old Jun 15, 2007 | 02:39 AM
  #13
Argon's Avatar
max goes thru a realy...but the relay is part of the resistor...the square box part
Old Jun 16, 2007 | 09:34 PM
  #14
Sinjin1952's Avatar
Member
Hello Argon:
Stopped by the Chevy dealer's parts dept. today. Got the following:
Resistor box $ 55.25
Connector$ 111.63
But got to thinking about things, my truck is a '05, less than three years old,
And has 25,000 miles on it.
Althought I bought it used, it is still under the 36 month/36,0000 mile bumper to bumper warranty.
I talked to a service manager and he said bring it in and they would fix it. Duh! I hadn't thought about that til now!
We'll see if it all works out.
Regards,
Randy, Las Vegas
Old Jun 16, 2007 | 10:55 PM
  #15
Argon's Avatar
kewl!
Old Jun 20, 2007 | 10:15 PM
  #16
Sinjin1952's Avatar
Member
Hello Argon:
Took the truck in to the Chevy dealer today and they repaired it under warranty, sure glad for that! They installed the resistor and connector. Works fine now. Hope it sticks!
Thanks again for all the input on this subject, wouldn't be surprised if it helps others too!
Regards,
Old Jun 21, 2007 | 04:10 AM
  #17
Argon's Avatar
Glad she's cooling!
Old Jun 21, 2007 | 04:11 AM
  #18
Argon's Avatar
go back in a couple of weeks and complain of a steering rattle...get em to put the new shaft in free.
Old Jun 21, 2007 | 09:48 PM
  #19
Sinjin1952's Avatar
Member
Argon:
What steering shaft are you speaking of, and if I don't currently have a problem, why would I want a new one?
Are they a widespread problem?
More good info please.
Regards,
Old Jun 21, 2007 | 09:58 PM
  #20
stopspazinout's Avatar
yes. they wear out a little and develop a squeek to them. theres a recall on those i believe.
