AC upgrade
That is a good way to tell, but not 100%. Alot of cheapo's out there will convert them and keep the same R134 Adapter for the next one on their charging set-up. Most people are just pumping 134 in an r12 system to get them over the curb anyway. It will work, but will probably leak out shortly. If your system is full I would have a shop evacuate it and assume it has not been converted. Unless like RUFFNECK4LYFE said it has the 134 fittings on it already. If it doesn't it really isn't as complicated as once thought to convert them. I have had great luck with just swapping out all the o-rings (cheap) and the accumulator (cheap) and flushing out the rest of the system really well with denatured alcohol. Get a set of 134 fittings, vacuum it down and charge it. Don't forget the PAG oil. Good luck...it's getting hot out there!
Trekerjohn
Oct 29, 2006 02:22 AM
briggs4811
Jul 2, 2006 05:56 AM
