-   -   Air Conditioner Cycle Switch (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/air-conditioner-cycle-switch-6852/)
sking2127 Apr 7, 2008 02:10 PM
The A/C Compressor does not stay engaged on my 2000 Z71, 5.3L, V8. When the compressor is running the A/C is Ice Cold, however it will eventually turn to blowing outside temperature air (which in Alabama in August is not pleasant). If I push the A/C button in the cab to turn the A/C off, wait a few moments and then turn it on again, the air again is ice cold. I've done this while the truck is idle and when I push the A/C button you can hear the compressor clutch engage. This led me to beleive that for some reason it's disengaging when it shouldn't be. A buddy that has a Tahoe suggested the switch on the side of the accumulator (A/C Cycle switch or high pressure cutoff switch?)is a relatively easy and cheap fix that may solve the problem.
Anyone have any experience with this and/or know what the switch is called?
Argon Apr 7, 2008 02:16 PM
RE: Air Conditioner Cycle Switch
its a cycling switch...or low pressure cut-off switch....pretty good bet thats the problem...COULD be a weak compressor clutch
jcbst12 Apr 7, 2008 02:22 PM
Is it possible it could just be on the border line of being too low on R-134A to allow the compressor to stay on?
Argon Apr 7, 2008 02:50 PM
DOUBTFUL IF IT GETS ICE COLD WHEN ITS ON...its most likely the switch..but..as usual..she needs to be checked to know fer shore
sking2127 Apr 7, 2008 02:54 PM
Thanks, I'll give it a shot!
goldenhammer Dec 30, 2009 08:57 PM
Would lack of refrigerant cause the compressor to NOT engage? I had similiar problem except no AC engagement at all. Replaced the AC cycling switch still nothing. But i can run a jumper directly from the battery to the AC compressor and it does engage.
goldenhammer Dec 30, 2009 08:59 PM
Did replacing the AC cycling switch solve the problem?
