Air Conditioner/Heater only works on high
Old Apr 12, 2009 | 07:29 PM
jwad10's Avatar
Default Air Conditioner/Heater only works on high
Like title says, it only works on high. Everything works fine except it only works when it is on highest. I have a 2000 silverado.
Old Apr 12, 2009 | 10:27 PM
Sounds like a blower resistor gone bad. Here is a link to one on eBay
http://cgi.ebay.com/ebaymotors/2000-...Q5fAccessories
Old Apr 12, 2009 | 11:15 PM
jwad10's Avatar
think so? i had a guy tell me it had to be some type of air conditioner switch, because i have options 1-5 from low- high and it only works on 5. im not saying your wrong i just want to be sure before i go by the part i need.
Old Apr 12, 2009 | 11:27 PM
jwad10's Avatar
well never mind, i did some researching and i believe you are absolutely correct. thanks
Old Sep 11, 2009 | 04:13 PM
scortch's Avatar
I'm having the same problem. Do you have the part number for the resistor? The ebay link is dead.
Many thanks!!
Old Sep 12, 2009 | 02:51 AM
chevy112488's Avatar
no doubt. on high it bypasses the resistor, so if it only works there you know the problem.
Old Sep 14, 2009 | 10:36 AM
slimburns's Avatar
Definately the resistor, I had the same problem twice on the 2001 I used to have. Dont' have the part number, sorry.
Old Sep 14, 2009 | 02:25 PM
bfg112's Avatar
Part number from Advance Auto is RU1064. Price is $28.99. Takes about 5 min total. 2 min to change the part, 3 more minutes to finish your beer.
Old Sep 14, 2009 | 03:57 PM
i like your style haha
Old Sep 15, 2009 | 07:03 PM
bowhunter's Avatar
Default resistor
After reading another post on this I found the location of the resistor. It's located below the glove box by the fan motor. You have to remove the plastic panel cover to access it. Bought a new AC-Delco resistor (made in SLOVENIA) part #15-81087. Cost me $36 bucks at KOI parts store. Took about an hour. Remember...I'm kinda old. Blower works fine now. After removal of resistor it was easy to see it was a little cooked. Thanks for all the inof on the forum! Next job is fuel pump Since I have a fifth-wheel rig in my bed I think we'll try removing the tank instead of the bed...
