Auto to Manual Swap
Old Apr 16, 2009 | 12:30 PM
BenRauls's Avatar
Default Auto to Manual Swap
Anyone done this on a 98 k-1500? Sick of buring up 4l60's. think of a NV4500 havent decided on a t-case yet. What was the worst part of it?
Old Apr 16, 2009 | 02:36 PM
DamnYankee's Avatar
Stick an 80-e in there...
Old Apr 16, 2009 | 11:21 PM
dmccartyfan's Avatar
I'd imagine it's quite involved (though I have the 60e as well) - just to give you an idea, I went looking for an ignition cylinder for mine and even THOSE are different for auto and manual. The manual ignition cylinder has the key release button and costs about $40 more than the one for auto.
Hey Yankee - is the 80e a direct replacement for the 60e? Mine's going on 150k miles and I'm just waiting for the day my 3 and 4 clutches burn up and I'll have to decide the best way to do it right the first time... do HD overhaul or replace it with the 80e?
Old Apr 17, 2009 | 12:30 AM
BenRauls's Avatar
Default Auto to manual swap
What about the electonics, does th 80-e plug right in? Same length as the 60? Are the80's that much stronger? 100k and 2 60's burnet up already
Old Apr 17, 2009 | 09:04 AM
DamnYankee's Avatar
80e's are a LOT stronger (clutch size being one of the advantages)...you would need a different harness (nelsonperformance.com)...the 80e is longer and uses a different yoke, you would need to tune the PCM to accept the 80e, but the conversion is worth it in my opinion. Or go with a turbo 400 and lose overdrive.
Old Apr 18, 2009 | 11:18 AM
chrisbmo2000's Avatar
Ive been down this road and IT IS NO FUN.........lots of swapping and changing.....the clutch pedal assembly is the hardest unless you can get one from a salvage yard but at that point you still have ALOT of work ahead of you....I did this on a 78 Chevy P/U so I had it easy compared to the electronics nightmare you have to deal with on a 98.......but it can also be a great learning experiance.....ITS NOT A WEEKEND JOB!!!!!!!!!!!!!!!!!!!!
max
May 16, 2010 10:26 AM
muncheys
May 19, 2009 08:20 PM
robs2500
8
Dec 18, 2007 09:12 PM
tedprice
May 30, 2004 12:29 PM
