Backup Light install question
Old Nov 8, 2006 | 12:50 PM
williamcarr03's Avatar
Default Backup Light install question
Hi All,
I have a quick question. I own a 2006 Silverado and would like to install (auxiliary) backup lights. What is the easiest way to wire them? I don’t want to use a switch. I want them to come on when I put the vehicle in reverse. Any help or information would be greatly appreciated.
Thank you,
Bill
Old Nov 8, 2006 | 06:33 PM
makoltd's Avatar
Default RE: Backup Light install question
If you remove your rear lights, you will see the loom (wire group) that has about 18" you can pull out to find the right positive wire. Simply attach the positive from you BU lights to the same light which comes on in reverse and attach the Neg to the truck. You might want to upgrade the fuse from a 10amp - 15 amp. My simple way may not be the only one but it works. You will need to do each light independently and not use just one side.
GL
Greek
Old Nov 10, 2006 | 08:52 PM
Thanks Makoltd,
It worked liked a charm. Now I can see...
Bill
Old Nov 12, 2006 | 01:23 AM
makoltd's Avatar
Great,,
Old Dec 12, 2006 | 01:43 PM
buckmeister2's Avatar
mako,
excellent answer. one twist i might add is that you can just pull the original back-up bulb and you won't have to add or upgrade the fuse. since you have installed more powerful bu lights, the old ones aren't needed anyway.
jim
Old Mar 12, 2009 | 08:11 PM
gixxer32404's Avatar
Default reverse/ back uplight not working
I was thinking about doing the same thing. But right now my reverse light on 96 s10 doesn't work. Is there a fuse for reverse light? It has a trailer 4 prong hook up on it. changed bulbs,used test light no power with key on in reverse.any ideas??
Old Mar 14, 2009 | 01:36 PM
ghlkal's Avatar
Member
Another thought on auxiliary backup lights:
If you have a 7 pin trailer plug, you have the backup light circuit there too. You can buy, or make, lights that plug into the harness. Check out "snow plow reverse lights" on eBay or plowsite.com for more information.
Old Mar 14, 2009 | 02:38 PM
What about the 4 pin flat trailer plugs???????
Old Apr 10, 2009 | 11:52 PM
Reverse lights work now. It was the sensor on the tranny.
Old Apr 11, 2009 | 12:49 PM
ghlkal's Avatar
Member
Thanks for following up.
BTW, a 4 pin connector does not have the backup light signal (left turn/stop, right turn/stop, normal lights, and ground)
