Originally Posted by ghlkal
(Post 43587)
Thanks for following up.
BTW, a 4 pin connector does not have the backup light signal (left turn/stop, right turn/stop, normal lights, and ground) np....thanks. It is on the driver side of tranny. There's 2 sensors. One is reverse light switch/sensor. It has be disconnected and takes a 7/8 deep well socket.Think it was hidden by cross member. The speed sensor which leaks fluid when removed had a bracket a bolt holding it on. It was a pita(pita=pain in the ---) This is on a 96 4.3L 2wd ext cab. I just wish someone could answer my shift light question thread/post. |
| All times are GMT -5. The time now is 08:58 AM. |
