bad bearing
Old Nov 7, 2007 | 02:00 PM
tayoz00's Avatar
Default bad bearing
As some of you know my oil pump has failed on me and i buaght a rebuilt engine for 500 bucks. i was thinking instead of spending all the time to put the new engine in if it was worth my time putting a new oil pump in and going from there? the engine turns but wont start. many people have told me i probaly have a bad bearing or threw a rod.
Old Nov 7, 2007 | 06:44 PM
Cracker's Avatar
Default RE: bad bearing
If you had an oil system failure you should spend the time to swap or rebuild. When the pump goes out the entire engine is damaged, every moving and stationary piece from top to bottom. Sorry to be the one to break it to you. The good new is the rebuilt engine has probablybeen bored, depending where you got it.
Old Nov 7, 2007 | 08:36 PM
tayoz00's Avatar
ya i baught a new engine last week still a 350 the guy told me it was set up for marine standards meaning it was going to go in a boat. Also he said it has a mild cam in it. Im excited to hear it.. i was thinking anotther thing maybe swaping the heads to the Vortec heads still am debating on that
Old Nov 7, 2007 | 08:39 PM
Cracker's Avatar
Have the old heads checked out by a good machine shop before putting them on your new motor. They may have been damaged when the oil quit.
Old Nov 7, 2007 | 08:40 PM
Cracker's Avatar
Was the new motor originally a marine motor. If so it is lighter than a standard iron block. Marine motors have a higher percentage of nickel.
Old Nov 8, 2007 | 07:37 AM
jcbst12's Avatar
What else is different between a standard engine and a marine engine? (Besides the uniform......ba-dum ching!)
Old Nov 8, 2007 | 07:40 AM
Cracker's Avatar
The accessories obviously, I think the cam and heads are focused more on torque than HP. The internals for the most part are the same, I think.
Old Nov 8, 2007 | 07:47 AM
jcbst12's Avatar
Isn't there a difference in the water jacket or something?
Old Nov 8, 2007 | 09:35 AM
Cracker's Avatar
I seem to remember something about that but I can't recall what it is.
There was a short time when marine 400ci motors were the rave and most people were using the short block only, I think.
Old Nov 8, 2007 | 05:24 PM
tayoz00's Avatar
ya im pretty sure it was a marine motor and yes it has a mild cam also im thinkin 100 shot nitrous
