bad idle if you touch break
Old Aug 10, 2009 | 06:22 PM
old as dirt's Avatar
Default bad idle if you touch break
on a 1994 silverado if you depress break pedal, the motor will almost die. Have checked for vacuum leaks but found none. any suggestions?
Old Aug 10, 2009 | 08:37 PM
chrisbmo2000's Avatar
Its a vacuum leak for sure.................but it could be hidden by A. a bad brake booster i.e. if the diaphram in the booster is bad) seen it several times.....B. intake manifold (check with carb cleaner) also check the vacuum "tap" for the brake booster(where it comes out of the intake)...if it is cracked it will cause major problems like that........have you "given" it a vac leak to see if the idle changes? this will tell you if you have an active vac leak that is made worse by the brake booster.........................these are areas I would start with if I had this problem
Old Aug 10, 2009 | 09:12 PM
When I pull a vacuum line off the Idle increases, sometimes a lot.
Old Aug 10, 2009 | 11:43 PM
ok then I would say you have a bad brake booster then
Old Aug 11, 2009 | 07:30 AM
I agree it is a leak internally in the booster allowing too much of a vacuum leak when the brake is depressed.
Old Aug 12, 2009 | 01:19 AM
RUFFNECK4LYFE's Avatar
Yeah when press the brake pedal you might hear the normal air noise but louder. An indicator the booster is bad.
dragonfly
Aug 11, 2012 01:16 AM
JJ CHEVY
Jan 31, 2012 08:26 PM
jkwallz
Feb 6, 2011 02:42 PM
zleehw
Mar 9, 2010 12:28 PM
zstonebigchevy
Nov 27, 2008 11:25 AM
