beat my horn to death
Ok so long story short... i bought a nice set of furniture and drove home and it wasn't supposed to rain and it did. I was pissed.
So... in a dumb moment i slammed my fist on the top part of the steering wheel (not the center) a couple times. The next day, i notice that my horn doesn't work. Maybe a coincidence but I doubt it.
Checked the horn fuse in the engine bay fuse box... its fine, replaced it anyways.
Any suggestions?
Any suggestions?
Maybe do an ohm test on the relay... idk what the specific ohms is supposed to be (70ish?), but I'm sure if it's anything but infinite and 0 you're doing alright.
If it's good, a crappy clip might've just fallen off in your wheel. I hate steering units.
for the ohm test... let me make sure i got it straight.
remove relay
put the leads from my multimeter to the slots from the fuse box. One each
turn the car on and have someone honk the horn?
how do i remove the plastic piece on the steering wheel to check for a clip that fell off without setting the airbag off in my face?
remove relay
... dukes, what do you think all those extra sweet n sour sauce containers you get from McDonald's are for?
@Nullhead, autozone told me also to wait an hour as well... why is that? do the airbags have a pressure buildup or something?
The airbag system contains a large capacitor (electricity reserve) to make sure the airbag deploys no matter what. If the event of a front end collision your battery cables get severed, what's to say the air bags should deploy? The capacitor is what supplies the voltage to deploy the air bags.
The airbags themselves contain a chemical that actually does the deployment. There is no pressure even in the airbag its self. It's a nylonish bag that's tightly packed with powder that gets fired by a gunpowder type blast that happens inside the airbag to make it deploy and inflate at the same time in a super small amount of time.
There is spring tabs behind the bag that may have been damaged. Behind the steering wheel there are 2 holes you gotta push a screwdriver to release 2 tabs and the bag comes off.
