Belt noise
Old Dec 2, 2007 | 07:10 PM
Cracker's Avatar
Default Belt noise
I did this to myself.....when I changed the T-stat I got coolant on the belt and at least one pulley. I rinsed them before start up with clean water. Occasionally I get a hampster wheel sound under the hood and I know it's the belt. I am hesitant to use a belt dressing or spray random products on the belt for fear I could damage it. Any recommended products or suggestions?
Old Dec 2, 2007 | 07:22 PM
Argon's Avatar
Default RE: Belt noise
the BEST thing is a packy of silicone grease that comes in brake pad boxes....
holding a bar of soap against the belt as its runninghelps sometimes...but BE CAREFUL!
Old Dec 2, 2007 | 10:26 PM
Cracker's Avatar
My Uncle Nine Fingers advises against holding the soap.
Thanks, Argon.
Old Dec 3, 2007 | 09:09 AM
jcbst12's Avatar
Don't do the dressing, I tried and made a mess. Mine makes noise too especially when its cold. Same deal, it was fine until thermostat change and I covered the street in coolant, lol. Bye bye stray kitty cats! (yes I drained the rad first but appartently that wasn't enough).
Old Dec 3, 2007 | 09:52 AM
Argon's Avatar
Give me your address if you want,I'll mail ya a ketchup packy of that lube
Old Dec 3, 2007 | 10:23 AM
Cracker's Avatar
Thanks, but, I'll pick one up from the local Auto parts store.
Old Dec 3, 2007 | 10:46 AM
Argon's Avatar
ok..let me know if you (or other guys here) need 1...I got a drawer full of em...don't worry about freight,I know how to use the dealerships postage machine!
Old Dec 11, 2007 | 11:17 PM
kuh99fuss's Avatar
Dressing or lubricants are a bandaid. If they work fine, but you will probably have to keep reapplying them every few days. You can try taking the belt off and wiping it clean with a rag soaked in mineral spirits (paint thinner). Wipe all pulleys real good also. This may or may not work, because the belt is somewhat porous and antifreeze is hard to clean off of anything. Whenever you put a new belt on, be sure to clean the pulleys real good first.
Old Dec 12, 2007 | 05:24 AM
Argon's Avatar
the kethup pack is the cure..ok,no one believe me...
Old Dec 12, 2007 | 09:10 AM
72charger's Avatar
I believe you bro! Just don't have a squeeling belt to put it on.
