Brake caliper sticking
Old Sep 24, 2009 | 12:24 AM
texag's Avatar
Default Brake caliper sticking
Howdy, I have a 2005 Chevrolet Silverado and I think the caliper is sticking on the front driver side. The reason I think it is that is because I changed the pads and only one pad was worn down, the other three had at least 75% on them. any suggestions? (If it helps any my truck has drums in the rear and disk in the front and they are not heavy duty)
Old Oct 5, 2009 | 11:37 AM
bigchevy's Avatar
Member
i had a similar problem w/ a jeep i used to have, the driver front would stick and heat up and i would have to kinda steer to the right to keep it going straight, but as soon as i needed to brake, it would jump to the right. it ended up being a faulty caliper. i replaced it and never had a problem w/ it again.
Old Oct 5, 2009 | 02:03 PM
RUFFNECK4LYFE's Avatar
Yeah sounds like the piston is bad on that caliper.
Old Oct 6, 2009 | 07:08 AM
Also check the sliders on the pad bracket. The new pads should have come with a set. I also lube mine so the pads slide back and forth easily.
scott_z71
14
Oct 10, 2019 07:26 PM
Tnoyes
Nov 2, 2010 03:25 PM
Steakumm
May 18, 2009 10:14 AM
MGP
Mar 10, 2009 08:04 PM
nextlevel
Aug 12, 2007 07:51 PM
