A/c clutch air gap tool
1 Attachment(s)
My 1996 5.0L, auto, Silverado has too much air gap in the A/C clutch plates and I was wondering if any of you know if the outer plate can be adjusted in, or pushed in closer to the magnetic plate, and exactly which tool would do this. I see those tool kits on eBay but I can't determine if any would fit my clutch shaft. Neither Autozone not O'Reilly's had that tool. Please look at the attachment to see which compressor I'm talking about, and could you ID it for me? I know it's a Delphi but that's about all I know. Man! Is it hot in Missouri!!! I need it bad!
Honestly, I would probably replace the compressor. It will come pre-set and ready to go.
Are you sure the compressor coil is getting good power and ground? It could be that your compressor is shot and all the clutch material is worn off of the plates and they're slipping. Usually you can adjust the clutch air gap by changing the shims inside the clutch/coil assembly, but I can't even begin to tell you how to do this. I know there is a special wrench to hold the clutch so you can take the nut off of the snout of the compressor, but beyond that, I really can't tell you what the spec should be, or how to adjust it without shims. So I'd replace the compressor. |
Originally Posted by NullHead
(Post 81144)
Looks like this powerbuild kit comes with a tool that looks extremely similar to the one he's using in the video.
I'd ask Advanced Auto if they have an A/C clutch hub kit and just rent it from them. It's 100% free, you just pay for the tool as a down payment, and when you return it, you're refunded. |
(Post 81155)
Looks like this powerbuild kit comes with a tool that looks extremely similar to the one he's using in the video. Alltrade 648995 Kit 65 Air Conditioning Clutch Removal and Installation Tool Set - Amazon.com
Well I guess to answer your original question, I have no clue how to tell what that kit works on. You'll have to find one locally and take a look, or take a chance and order it online.
