A/c compressor clutch fuse keeps blowing
Old Jul 23, 2017 | 10:40 AM
rebranger's Avatar
Question A/c compressor clutch fuse keeps blowing
have a 2004 Z71, 5.3 V8, auto. All of a sudden the A/C clutch fuse began blowing. Disconnected connector on compressor, NO fuse blowing. Replaced A/C compressor, vacuumed & re gassed, A/C works fine for about 30 min, then blew another fuse. Removed plastic bottom shield (shroud) to get to wiring harness which was grommet-ed (attached) to around exterior of oil pan/block junction. Removed protective plastic wire shield. At the juncture of the wiring harness split on the passenger's side, the wires were very warm to the touch, no smoke, no burned wires, no shorts that I can find. It appears to be a bad connection in the circuit or a bad sensor somewhere. Anybody have any ideas of what/where to check next? PCM under hood had a 10 amp fuse, replaced it with a 20 amp, A/C ran a while (20 min, normal driving) then blew again!!
Does the engine temperature sensor (drivers side towards front) have anything to do with this clutch control circuit?
Old Jul 26, 2017 | 06:55 PM
rebranger's Avatar
Found it!!! Wires were rubbed raw & shorting.
Location: Where the harness is routed around the front of the oil pan, compressor side, between the engine block & transmission oil cooler lines!
Old Jul 27, 2017 | 06:48 AM
SlimJim's Avatar
Thanks for letting us know what you found.
Old Jul 1, 2020 | 01:46 PM
Russmeats's Avatar
Hey man! Thanks for making this thread, I have the same issue with my 2006 silverado 5.3l 4x4. How did you go about fixing the wires issue?
Old Oct 24, 2021 | 03:33 PM
Lmizell's Avatar
Default Thanks!
Your completed story is very helpful. It's always a drag to find soomeone with a similar issue, only to never hear of the resolution! I am in the middle of this problem right now!
93chevystepside
Silverado/Sierra FAQs
Jan 27, 2014 06:23 AM
80skeys
15
Oct 11, 2010 12:44 PM
Robrt32
10
Apr 11, 2010 07:55 PM
ahcapone
Feb 2, 2009 10:59 AM
bluedakota
Apr 21, 2007 10:27 PM
