Can Anyone Help Me????
Old Jan 6, 2008 | 03:13 AM
Westly's Avatar
Default Can Anyone Help Me????
I have a 2000 gmc sierra that has 152,000 miles also it hasbeen given me problems that i can't figure out. Like i have just got a brand new alternator and a new battery. It will start up but the voltage guage stays between the 9 and 12 and eventually drops, then my truck dies. Some of the peoplethat i have talked to saidit mightbethe ingectors, orthe resistor but im not for sure. This has not ben occuring just once either. It would be my 3rd batterya3rd alternator, though i know for afact that they are not the problem.Just wanting to know if anyone could help mesolve my problem.
Old Jan 6, 2008 | 06:13 AM
Argon's Avatar
Default RE: Can Anyone Help Me????
it dies...does it restart?..do you have to jump it off?...it run doqwnm the road ok?
Old Jan 6, 2008 | 07:14 PM
southcomfort09's Avatar
check all your wiring.
Old Jan 6, 2008 | 10:51 PM
Westly's Avatar
It started up today when i went to crank it. The other night though when i pulled into my driveway it died. When im driving down theroad the batter lightstays on andmydash lights and every thing eventually fade to where your guages dont work. I havent jumped it off because i know it wouldnt helpit cause i have anew battery. And i had everything tested at autozone andmy alternator and battery arefine.
Old Jan 7, 2008 | 06:12 AM
Argon's Avatar
check the connection at that red plastic box the battery cable passes thru...i've seen thos corrode under that big nut and not let the amps get to the battery
Old Jan 7, 2008 | 11:18 PM
Westly's Avatar
I have already checked it and it is secured tightly on to the bolt.
Old Jan 8, 2008 | 04:45 AM
Argon's Avatar
but make sure its not corroded..take the nut off and check...
and make sure your getting 12v to the alternator on the big wire and at the little connector
fast400ex
Sights N' Sounds
Jul 13, 2012 03:10 AM
Toolman
Jan 29, 2008 08:33 PM
pradke
Nov 2, 2007 09:56 PM
Argon
Jul 29, 2007 12:58 PM
