CEL with a P0449 code
HI all, got this code now running a '00 1500 5.3 Silverado. Any help to fix this problem would be great...my Haynes manual is not of much use. Pretty sure it has something to do with the vent valve SOLENOID, perhaps a wiring problem. Any help would be great. Also, where is this thing located?? The manual says near the gas tank, but mine appears to be on the inside drivers side rail pretty much right under the door. Is this it? No wires appear broken or cut, etc. Thank you!
P0449indicates the PCM is not seeing the voltageitexpects. The problem could be the solenoid, wiring, or the PCM.
My experience is it's usually a wiring issue (I find this our after replacing the part [:@]) YMMV
ORIGINAL: hawks
was your solenoid located in the same place as I describe above?
DTBird
Sep 26, 2010 11:09 AM
klrjoe
Dec 7, 2005 05:32 PM
