CEL question
Old Jun 6, 2010 | 09:53 PM
fr8train's Avatar
Default CEL question
the Check Engine Light (CEL) on my truck 2005 Silverado Z71 4x4 5.3 is not working. Is it just a bulb that I can replace? Or, is this one of those vehicles where everything is part of the circuitry and I'll have to replace the unit?
Old Jun 7, 2010 | 08:11 AM
RUFFNECK4LYFE's Avatar
The cluster has seperate bulbs for each indicator.
Old Jun 7, 2010 | 05:24 PM
fr8train's Avatar
Thanks, anything I should know about before I dig into the dash? Or anything that can/should be replaced while I'm in there?
Old Jun 7, 2010 | 08:00 PM
Mine was simple, just took off the trim and then 4 bolts holdin the cluster and she comes out after unplugging the harness. In the back of the cluster you will see the base of the bulb holders twist and come out. There is several so make sure you replace the right one.
Old Jun 8, 2010 | 01:56 PM
Mad Max's Avatar
Haha /agree with Ruffneck, I can say from experience that it sucks when you put it all back together, only to find out you replaced the bad bulb with another bad bulb lol.
On a side note, its always a good time to install aftermarket gauge faces as some of the work is done already.
DTBird
Sep 26, 2010 11:09 AM
Fox
Feb 3, 2009 05:13 PM
hawks
Jan 26, 2009 06:39 PM
