CHANGING TRANS. PAN GASKET
Old Aug 22, 2007 | 06:13 PM
RobF1970's Avatar
Default CHANGING TRANS. PAN GASKET
Planning on changing out transmission pan gasket this weekend. Does anyone have any idea what type of gasket is best? Also, what are the torque specs on pan bolts? I don't want to over tighten them and pinch the gasket.
Thanks
Old Aug 22, 2007 | 06:15 PM
BlackHorse99's Avatar
Default RE: CHANGING TRANS. PAN GASKET
Good luck with the tranny drain plug.....
Old Aug 22, 2007 | 06:24 PM
RobF1970's Avatar
It has no drain plug...
Old Aug 22, 2007 | 09:08 PM
racethisz71's Avatar
rtv is yor best bet but let it sit for 24hrs to fully cure
Old Aug 23, 2007 | 04:39 AM
impaladakid's Avatar
FEL-PRO is the way to go. I use a light bead ofgasket sealer to hold it to the clean pan, then another light bead between the gasket and the trans. I usually let the trans drain for an hour then whip clean with cab cleaner on a rag. Just torque to factory specs.
Bill
Old Aug 23, 2007 | 05:52 AM
Argon's Avatar
use NO rtv...that **** has ruined many a trans by getting into stuff./..a gm or felpro gasket is all ya need....use a lint-free cloth to wipe the tranny clean
Old Aug 24, 2007 | 01:26 PM
Cracker's Avatar
I had to rebuilda 700R4 twice because of RTV.........I didn't know what was in the fluid channels until the third tear down.
dakomish
Silverado/Sierra FAQs
Sep 28, 2012 02:00 PM
azjetfighter
Nov 23, 2011 09:25 PM
DOBERDEWD
Jul 7, 2010 08:48 AM
Mr_Shamrock
Aug 17, 2009 11:22 PM
straightcrazychevy
Mar 2, 2008 02:16 AM
