Chevrolet 350 intake manifold question
Old Apr 8, 2009 | 03:31 PM
CustomDK20's Avatar
Default Chevrolet 350 intake manifold question
Ok Recently I bought a edelbrock carb and manifold. While removing my old intake manifold. Two of the bolts broke off in the cylinder head on each side in the very back.. Well I tried an easy out to remove the first one which is passenger side at the back of engine, the easy out Cracked my cylinder head a little at the top, so Now I cant get the thread to lock, and Im afraid to tap again, because I already did once?????? So I JB Welded all around on the cylinder head around the broke out part. and sealed it pretty well.Will my truck run ok if I leave that back bolt out, I have all the rest of the bolts torqued down????????. I already had to take the other cylinder head to a machine shop, because I broke a tap off in side// So any help is appreicated. Thanks
Old Apr 8, 2009 | 04:01 PM
You will more than likely get a leak and your truck won't run right. It may not happen right away but eventually depending on how much broke off.
Old Apr 9, 2009 | 10:51 AM
CustomDK20's Avatar
What kind of leak/ Like a massive air leak? or water? there is no fluid or intake ports on the back? How much would my truck run like crap. would it be gasping?
Flip87
Nov 3, 2007 07:21 PM
JakeSilverado
Oct 7, 2007 03:13 PM
kirkstheman
Jul 3, 2007 10:35 PM
93 STX
Jun 9, 2006 11:54 PM
Sparky
May 26, 2006 02:11 AM
