cluster problem
just a hope quick question
i went on a 2 week trip when i came home found some one broke into my truck they stole the nav radio set up i do not know why but the cluster and glove box tore out also, some one told they must of been looking for brain of gps i don't know but cluster was on ground the back of it busted looks like step on i found another cluster but mileage off it has 9.000 something my truck had 24.589 on it i could get cluster reprogrammed is the mileage stored any place else want it to match what i had do not want any trouble later or put any sticker on door i have a 2015 gmc 1/2 ton 1500 with a 5.3
Take it to the dealer, make an insurance claim. Your truck is extremely sophisticated and difficult to work with electrically speaking. I don't suggest this be a project that you try and tackle yourself. Also General Motors says modules in new vehicles cannot be swapped like the old trucks, since the new body style, you can't swap clusters and modules out like that, they're far too complex now.
Good luck
Good luck
thanks these are not back yard workable to a point it is just that me and my insurance co i had a lot of problems in the past and just trying to stay away from then i just need a little more time before i start with then[get back in there good graces]
Well, I guess I don't know what to tell you then. As far as I know, there is no real good way to get a swapped cluster to work, but that doesn't mean it can't be done. Perhaps someone else here knows how to do it?
All I know is this:
http://www.revbase.com/BBBMotor/TSb/...dPdf?id=182965
All I know is this:
#PIP4670D: Do Not Swap Modules in Vehicles With Global Electrical Systems - (Jan 23, 2014)
Subject: Do Not Swap Modules in Vehicles With Global Electrical Systems
Models: 2010-2015 Buick LaCrosse
2013-2015 Buick Encore
2011-2015 Buick Regal
2012-2015 Buick Verano
2014-2015 Cadillac CTS Sedan
2010-2015 Cadillac SRX
2013-2015 Cadillac ATS, XTS
2014-2015 Cadillac ELR
2015 Cadillac Escalade Models
2010-2015 Chevrolet Camaro, Equinox
2011-2015 Chevrolet Cruze
2014-2015 Chevrolet Caprice PPV, Corvette, Impala, SS
2014 Chevrolet Silverado 1500
2015 Chevrolet Colorado, Silverado, Suburban, Tahoe
2012-2015 Chevrolet Sonic
2013-2015 Chevrolet Spark
2014 Chevrolet Spark BEV
2013-2015 Chevrolet Trax (Canada Only)
2012-2015 Chevrolet Volt
2014 GMC Sierra 1500
2015 GMC Canyon, Sierra, Yukon Models
2010-2015 GMC Terrain
This PI was superseded to update model list. Please discard PIP4670C.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
A technician may comment of a no start or another concern after swapping an ECM or other modules from one vehicle to another.
Recommendation/Instructions
The Global Architecture electrical system associated with these vehicles does not allow controller swaps between vehicles. Swapping ECMs or other modules (including Radio, BCM, EBCM, SDM, TCM, ECC (HVAC), EPS, HPCM, & IPC) between two vehicles with the Global Architecture electrical system will result in damaging both controllers (A NO START CONDITION WILL OCCUR ON BOTH VEHICLES IF THESE MODULES ARE SWAPPED) due to the new vehicle security code protocol (environment) starting with the 2010 MY GDS applications.
ADDITIONAL SI KEYWORDS:
B389A B3902
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
Condition/Concern
B389A B3902
skobiak
Dec 23, 2009 10:42 PM
