Dash cluster out
Old Oct 8, 2007 | 09:30 AM
Cracker's Avatar
Default Dash cluster out
I like to hear your diagnosis. 2003 Suburban w/5.3, runs fine, dash lights work, instrument panel gives no readings. No speedo, trip, oil pressure, engine temp, or gas......everything is out but the lights.
Old Oct 8, 2007 | 09:41 AM
Cracker's Avatar
Default RE: Dash cluster out
Cluster came back on, however, this may be an intermittent event and I would still like to hear your thoughts.
Old Oct 8, 2007 | 10:17 AM
jcbst12's Avatar
Just a guess but maybe it has something to do with the Hypertech programmer cause when you flash the computer with it, the guage needles go back and forth a few times. Maybe it needs reset or there is simply a glitch in the ECU?
Old Oct 8, 2007 | 10:32 AM
Cracker's Avatar
Good idea, J. But it's not my truck, sorry, I should have specified. It's my friends vehicle. The only aftermarket piece on his ride is a K&N filter.
Old Oct 8, 2007 | 10:47 AM
jcbst12's Avatar
Oh sorry. A bad ground? Bad contact on the board? I had lighting probs with my dash cause the contacts for the bulbs were junked up, but never had jumpy guages before. If its runnin ok I don't see it being the ECU, but you never know.
Old Oct 8, 2007 | 12:21 PM
Argon's Avatar
gm has a recall out on some bad clusters...check with your dealer
Old Oct 8, 2007 | 01:18 PM
Cracker's Avatar
Will do.....thanks
Old Oct 8, 2007 | 03:17 PM
Cracker's Avatar
Not a recall.....if problems persist the cluster is $350 plus another $150 to install and program the cluster. Thanks for all your input.
Old Jan 28, 2008 | 02:00 AM
jpgoodnu's Avatar
Member
GM DOES have a campaign on their clusters,my coworker just got a letter from Chevrolet about his 2003, they are replacing them for free depending on your mileage(BULL****,they know they had a problem). They had a real serious problem with the damn things.
Old Jan 28, 2008 | 07:50 PM
MrLM7's Avatar
Just have him go to a junkyard and snag one out of a HD... Get a trans temp gauge...
