Code P1345
I just replaced the intake manifold gasket and had a rough running 1997 5.7 engine, I retimed it but now I have a trouble code of P1345 and I can erase it with a code scanner, any one know how to get rid of this code and if it won't go away will it hurt to drive my truck? Thanks
As acnas stated, the Cam offset or "Camshaft Retard Offset" as GM calls it must be set.
Most inexpensive scan tools cannot perform this function and the timing can only be set with a good scan tool.
I would also start with the basics and be sure the distributor was re-installed correctly
klrjoe
Dec 7, 2005 05:32 PM
