Code Scanner Not Linking.
I purchased a code scanner(Autel maxiscan MS409 OBD2) so I can pull the codes from my 2003 Silverado. When I connect and turn on the key I get an error message saying that I have a linking error. The new scanner works on other vehicles without a problem. Also I already tried another scanner on my chevy, still no luck. My question is ...has anyone else had this linking error and what did you find to be the problem. Thanks in advance. :cool:
sounds like you blew the fuse for the interface....usually it it the same fuse that the lighter uses
Or power port uses.
Originally Posted by chevychase
(Post 64171)
Or power port uses.
LOL yeah thats what I meant......Im old school and call it a lighter still :D |
Originally Posted by chrisbmo2000
(Post 64169)
Originally Posted by 68Nwprt
(Post 64176)
Thanks crisbmo,you may be right. The power port has never worked.Now to find the right fuse. I believe that I checked them all in the past, is there something I'm missing?
OK Thanks I'll keep looking. :confused:
If the fuse is good, then the cig lighters is gonna be the problem. The OBII port is powered by this in series.
Originally Posted by RUFFNECK4LYFE
(Post 64184)
Looks like the cig lighter above the ash tray is in rough shape. I'll start with that one. Won't be till the week end. Thanks again.
