Cone air filter
Anyone here tried using a cone type air filter on the end of the MAF, replacing the actual air box, and descreening the MAF? I was thinking of trying this as a lower cost option, rather than buying a cold air intake.A cone air filter can be had for about $30, and the descreening is free. Any thoughts?
RE: Cone air filter
Yeah, check out the link... https://www.truckforums.com/m_27778/tm.htm
RE: Cone air filter
The problem is you have no mount for it so it will just be hangin down and beating on stuff as you drive around. I drove a Lancer OZ around like that for a while and the filter started rubbing on stuff and eventually almost rubbed a hole through the filter. If you can find a way to make it stay still and keep the filter from rubbing something you'll be set though.
If you do those and it works out real good let us know. I may try it. |
RE: Cone air filter
zip ties
RE: Cone air filter
I was thinking of building a box with a u shaped cutout on the filter side. Also, I was gonna use the stock air tube from the TB and just attach a filter to the MAF, instead of a whole replacement tube. I'll do it and post some pics when I am done. Thanks for the input.
RE: Cone air filter
Best bang for the buck from my research. A K&N air filter, Airaid Intake tube, descreened MAF, and TBS. You technically can't make use of any more air than that without a custom or dyno tune. Too much air will make the timing retard enough that it will actually decrease hp and tq 9 out of 10 times.
RE: Cone air filter
I was thinking of building my own ram air let me know how you build youre box.
RE: Cone air filter
Custom box would be sweet. You at least need a good heat sheild but a custom box would be better.
RE: Cone air filter
I was thinking about using some kind of duck work and putting that shinny silver stuff that looks like foil around it. Also I want to run air ducks up from the bumper maybe from were the recovery hooks are
RE: Cone air filter
Don't use stuff thats too flimsey. You'll never keep it together. The hooks would be the best place to put them. What year is your truck? I have a 99 and there are these little vents in the bumper that I was thinking about placing a scoop behind and running a duct to the intake. (Looks like two recesses in the black part of the bumper. The plastic plates can be removed and there are too vents underneith).
