coolant bypass???
Old Dec 9, 2007 | 04:00 PM
94 dodge ram 2500's Avatar
Default coolant bypass???
i have noticed that a couple different people have done coolant bypass on there truck. my question is how do you do it and what does it help?
Old Dec 9, 2007 | 06:09 PM
racethisz71's Avatar
Default RE: coolant bypass???
you bypass the coolant going to through the throttle body so the throttle will be cooler. you just take a fitting and connect the two hoses
Old Dec 9, 2007 | 06:15 PM
what does this do for the performance of the truck?
Old Dec 9, 2007 | 07:17 PM
Cracker's Avatar
The coolant path is from the heads to the throttle body, the coolant is hot. By passing this keeps the throttle body relatively cool compared to before the bypass. Cooler air is more dense. The gain is minimal is power and economy, but, it only costs $1.00 or so.
Old Dec 10, 2007 | 05:38 PM
smoke20's Avatar
Or free if your hose will reach. Mine reached from the passenger side of the radiator to the driver side of the engine, then I just moved the bracket that held it to the radiator. Then you just need the vaccuum caps to cover the throttle body holes.
Old Dec 10, 2007 | 07:43 PM
quick02's Avatar
And it doesn't have any possible side effects? Since a cooling line is being bypassed and all.
Old Dec 10, 2007 | 09:07 PM
Cracker's Avatar
The coolant lines from either side of the throttle body are connected to each other, therefore, the coolant is still able to flow through the heads.
ski7541
Sep 21, 2008 04:21 AM
EarnhardtZ71
Jun 28, 2008 06:10 PM
stevieGx33
Apr 4, 2008 09:33 AM
Chevycowboy
Mar 27, 2008 01:28 AM
smoke20
10
Apr 27, 2007 02:23 AM
