-   -   Dad's 2005 Silverado has not been run since last summer-- any recomended precautions? (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/dads-2005-silverado-has-not-been-run-since-last-summer-any-recomended-precautions-9227/)
billie Feb 24, 2009 06:41 AM
My dad has a 2005 Chevy 2500 truck with a camper that has been parked since last summer. He's been out of state since then so last summer was the last time it was running. Are there any precautions to do before starting it like treating the fuel or draining it if that's even possible? Thanks.
20''strong Feb 24, 2009 07:46 AM
Everything should be fine with the fuel,if the truck sets in the really cold climate in the winter yearly i would recommend fuel stabilizer.you can top off the tank and ad injecter cleaner to the tank just incase the gas broke down a little.that will keep the injectors from biulding up any gum.you also may need a jump box for the battery.and lastly i dont drive my truck to much in the winter unless the roads are nice so during the winter months i can go 1000miles in 8 to 9 months without oil change,but i do one anyway when it warms up.you might think of an oil change to,inside the moter can condense like a soda can does in the summer where you can get water mixed with your oil.
billie Feb 26, 2009 07:41 PM
Thanks 20"strong
Thanks for your reply! I'm passing your reply on to Dad.:) Billie
Mangled03gmc Feb 26, 2009 09:08 PM
I would dump some gas stabilizer in there as stated or even a few gallons of high octane-101 100.. You should be fine however.. :) Then run a fuel system cleaner through it.. Good to go
billie Mar 4, 2009 09:39 PM
I've been reading forums on fuel stabilizers and I see a lot of discussions regarding Sea Foam, Amsoil, Techron, Stabil to name what seems like the most popular. Is there a stabilizer and cleaner you could recomend?
20''strong Mar 5, 2009 09:36 AM
i used stabil when i had a boat and never had any problems,and i think stp makes one also.
billie Mar 10, 2009 12:33 AM
Thanks 20" Strong and Mangled03gmc for your help. Billie :)
