descreening MAF 97 suburban/PICS are added now
I assume the MAF descreen works on ANY truck that has a MAF. Any one do this to their late 90s truck? Im thinking about doing this to my 97 Suburban
RE: descreening MAF
... and for '98?
RE: descreening MAF
anyone got a "how-to" on this? Orat least some first-hand feedback related to long term performance/probs. Got me interested now... (for an '02).
Justcan't justify dishing out the $250+ forthat Jet Power MAF! |
RE: descreening MAF
Shredsled, we meet again :) For '99 and up, the answer is in the FAQ:
https://www.truckforums.com/m_17037/tm.htm None for older :( |
RE: descreening MAF
ORIGINAL: dmccartyfan Shredsled, we meet again :) For '99 and up, the answer is in the FAQ: https://www.truckforums.com/m_17037/tm.htm None for older :( Ah, thanks for the heads up! |
RE: descreening MAF
I think Im gonna try it......... I will report the results when I know
RE: descreening MAF
So I did the MAF descreen...it took about 5 min to do.......so here is how on the pre 99 trucks
First remove the air cleaner cover and unclip the MAF and aircharge temp sensor then unclamp both sides of the MAF and remove it takes a T-27 torx bit to unbolt the 2 halfs push the screen out with a screw driver or ratchet handle (mine came out in one piece) bolt it back together (it only goes together one way) reinstall and you are done maybe we can get this added to the other one for 99-up?! |
RE: descreening MAF
sorry guys I tryed to add pics but I see they didnt add can anyone help with this
RE: descreening MAF
Gahhhhhhhhhh TORX - another tool I gotta buy now :)
To add pix, the way I do it is to upload the pic to www.photobucket.com - if you aren't registered, go get registered. It's easy to get pix from your computer to photobucket. Then, once your pic is on their site, it will give you link information that looks something like this - EXCEPT YOURS WILL HAVE BRACKETS [] AROUND THE IMG PART (in order for you to see the entire link I had to remove the brackets at beginning and at end): IMG]http://i705.photobucket.com/albums/nameofyourphoto.jpg[/IMG Select and copy the link (I double-click it, then right-click, COPY). Paste it into your forum post (right-click, PASTE), then you HAVE TO CHANGE THE CAPITAL IMGs to lower case imgs, like so: img]http://i705.photobucket.com/albums/nameofyourphoto.jpg[/img Then, it will display your photo. Buzz me if it doesn't take it... but it should :) |
RE: descreening MAF
Very cool that it was an easy process tho. Let us know how it runs!
