DEX-COOL LAWSUITS - GET RID OF IT
Old Nov 8, 2006 | 06:49 PM
makoltd's Avatar
Default DEX-COOL LAWSUITS - GET RID OF IT
I have known about this for a few years but I thought that new Silverado owners or some who actually trust their GM Service Manual or even worst their Service Manager might feel the same shock that I did after learning that GM intentionally put Phosphates into the Dex-Cool Antifreeze. You who are not familiar with this and the many class action lawsuits that are now ongoing need to check out each of the links I provided below. I can only tell you one thing.
FLUSH YOU RADIATOR ASAP<- and GET THE DEX-COOL out of your trucks/cars. Use any GREEN Anti Freee such as "Prestone Green or Peak," but NOT Texaco or Penzoil as they make the Dex-Cool for GM and are identical. I hope this helps those who care as much about wasting money to satisfy GMs negligence as I do. The links below each offer a different problem Dex-Cool has brought on to GM owners.
GM states in the owners manual that it's Dex-Cool IS good to 150,000 miles. They now state that just because it is writen, is is NOT a warranty - WHAT THE HELL?
GL
Greek
GM knows they have a problem with Dex-Cool but they are not willing to correct this problem by going back the green coolant that did not have any problems, & when the Dex-Cool eats away the intake or water pump gaskets allowing the cooling system to leak coolant & get low it will start caking up in the cooling system. Gm dexcool is not due to be serviced until every 100k, I have looked at some vehicle at 30k & the dexcool already looks really dirty, I would recommend having the cooling system completely flushed EVERY YEAR & have green coolant put in the vehicle, unless you like buying intake, head & water pump gaskets. Maybe you've already had to replace a water pump just out of warranty...
JUST CLICK ON EACH LINK BELOW TO GO DIRECTLT TO PAGE AND READ
1.) DEX-COOL - FEAR ACROSS AMERICA - BLOWN ENGINES, HEATER DAMAGE AND IT JUST GETS WORST!@!
http://www.northwestclassicautomall....?pid=49&step=2
2.) GM under Legal Fire for Dex-Cool Related Problems - Radiator, Water Pump, Head Gaskets, Sludge build up - Intentional use of Phosphates !@!
http://www.imcool.com/articles/antif...le-Excerpt.pdf
3.) GM Owners Still Steaming Over Dex-Cool -Corrosion, Engine Damage Blamed on Coolant
http://www.consumeraffairs.com/news0...m_dexcool.html
4.) Class Action Lawsuits filed
http://www.wcpo.com/wcpo/localshows/.../20299ce7.html
5.) GM, Others Sued Over Dex-Cool
http://www.noln.net/features/feature3.html
6.) Dex-Cool Extended Life Engine Coolant problems in your 'General Motors' vehicle
http://www.geocities.com/b_gillie/dexcool_problems
7.) Intake manifold gasket failure
http://townhall-talk.edmunds.com/direct/view/.ef141d7
__________FAIR BALANCED "OTHER SIDE VIEW."___________
1.) GM and Texaco “Bare All” about DEX-COOL
http://www.imcool.com/articles/antif...l-macs2001.htm
Old Jan 6, 2007 | 07:35 AM
MrLM7's Avatar
Default RE: DEX-COOL LAWSUITS - GET RID OF IT
When you add the green stuff after the flush, add water wetter. It'll help maintain gaskets, seals, and protect against buildups.
Old Jan 6, 2007 | 08:06 PM
under construction's Avatar
what year did they start putting it in?
Old Jan 6, 2007 | 08:32 PM
smoke20's Avatar
Not to question makotd, but has anyone else heard of this? I just want to have all the facts before I start some crap. I just had to replace my waterpump @ $500 and I anly have 45K on my truck.
Old Jan 6, 2007 | 09:13 PM
GEARHEADRT's Avatar
SMOKE,
THAT IS TOTAL BULL****. 30K, AND THE WATER PUMP IS GONE? OUTRAGOUS!! RAISE HELL PAL!!
Old Jan 6, 2007 | 11:30 PM
smoke20's Avatar
Actually it was 45k and out of warantee. I have never had this issue before in any vehicle I have ever owned. I just need to know I am right. Then I can go rip some ********!!
Old Jan 7, 2007 | 12:13 AM
GEARHEADRT's Avatar
SMOKE,
THIS IS THE FIRST TIME I AM HEARING ABOUT THE DEX, BUT EVEN 45K IS TOTALY RIDICULOUS. I BET IF YOU RAISE HELL, GM WILL DO SOMETHING FOR YOU. GOOD LUCK AND LET ME KNOW WHAT HAPPENS
patmcg
Jan 9, 2011 06:13 PM
mjn030
Jan 21, 2010 04:58 PM
dmccartyfan
21
Feb 1, 2009 12:25 AM
adampgasser
Mar 20, 2008 09:05 AM
adampgasser
Feb 28, 2008 02:46 PM
