Did I screw myself on this?
Old Mar 2, 2008 | 09:03 AM
uscghalle's Avatar
Member
Default Did I screw myself on this?
I bought the K&N FIPK2 intake kit for my truck n Friday, picked it up this morning when I got off of duty. When I opened it up, the instructions said that it was not designed for vehicles with body lifts. I have a 3" body lift. Is this going to require timing or alterations to the system? 97 k1500 z71 5.7L
Thank You
Old Mar 2, 2008 | 09:15 AM
rxsteven's Avatar
Default RE: Did I screw myself on this?
I dont see why it wouldn't work as lond as you're engine bay has'nt changed from the lift
Old Mar 2, 2008 | 09:26 AM
uscghalle's Avatar
Member
I dont think it has changed (the lift was there when I bought the truck) I sent K&N an email asking them as well. thanks rxsteven
Old Mar 2, 2008 | 11:26 AM
rjdoolay's Avatar
When you lift the body off the frame the engin hight stays the same. With the FIPK you have to bolt the box to the fender which is now higher then the engin or at least higher then the stock position. Im not sure what you could to do fix it but im sure there is some way to rig it up to work. you might just have to drill a new hole in the fender well for the bolt.
Old Mar 2, 2008 | 03:17 PM
hunt4game29's Avatar
Not sure about your truck but when i just installed my body lift my fit just fine. Try it and see.
Old Mar 2, 2008 | 03:32 PM
jcbst12's Avatar
You MIGHT have to modify it to work, but honestly, it just not going to sit the same way it would if your truck was stock, it will still function the same.
Old Mar 2, 2008 | 07:25 PM
uscghalle's Avatar
Member
So do I try to install it anyway? Or wait for K&N input?
Old Mar 2, 2008 | 07:26 PM
Cvtsax's Avatar
Install it man you can make it fit
Old Mar 2, 2008 | 08:17 PM
uscghalle's Avatar
Member
I don't know...the last time I did something without thinking, it involved a bonfire and a hatchet. Needless to say, I now have the back of a hatchet branded into my arm lol.
It's too late to start now, and I should have K&N's response tomorrow (hopefully).
Thanks for the advice.
Old Mar 2, 2008 | 08:37 PM
rxsteven's Avatar
You can do it!!!!!!!!
bite its ****ing head off!!!!!!!!!!
