Door lock clicker
Hi guys I for got. But how do you reprogram the door lock clicker. I put new battery's in both of them and they do not work. Thanks for any help.
Here they are.........
1. Close all vehicle doors.
2. Insert the key into the ignition.
3. Hold down the power UNLOCK button on the driver's door panel-continue to hold down until instructed to release.
4. Perform steps 5 through 8 in fairly rapid succession.
5. Turn the ignition switch to the ON position (as far as you can go without starting the engine).
6. Turn the ignition switch to the OFF position.
7. Turn the ignition switch to the ON position.
8. Turn the ignition switch to the OFF position.
9. Release the power unlock button on the door panel. The vehicle will lock and unlock the doors automatically.
10. Hold down the LOCK and UNLOCK buttons on the transmitter simultaneously until the door locks and unlocks. This step may take up to 30 seconds.
11. Repeatstep 10NOWfor each additional transmitter (including any existing transmitters).
12. Turn the ignition switch to the ON position in order to exit the transmitter programming mode
I can tell you FIRST hand that it does.........I did not get a FOB with my burban...I bought one and used these instructions and it works great.
Joneebgood
Mar 17, 2008 09:52 AM
woody1071
Mar 14, 2008 08:58 PM
MrLM7
10
Apr 7, 2007 02:37 PM
