drain plug
Old Sep 12, 2008 | 03:15 PM
timber74wolf's Avatar
Default drain plug
Before I attemp to undo the transmission drain plug in the futureis there any good advice? Is it a good idea to drill out the threads and add a real bolt to it instead of the stock bolt?
And is there a trick to checking the transmission fluid? Everytime I check it it shows low or over full? I complained to the dealership about it checking low and adding a quart of transmission fluid... they just said it was fine.
Old Sep 12, 2008 | 11:02 PM
rxsteven's Avatar
Default RE: drain plug
My bolt wouldnt turn and I didnt want to break the head off so I just dropped the pan a little at a time. Also you might have to move the shift linkage over I think I popped out one of the little white ball things and bent it out of the way. But your truck might be a little differnt. When you fill it Id start with 5 qt's check it and then add if you have to. Also the trans has to be warmed up and the engine running when you check it. Oh and dont forget to get that little rubber thing for the filter out. I didnt do it the first time I changed mine felt bad and redid it all right the secound time. And you need to clean the old gasket off real good without scratching anything up. If you cant turn your drain plug try and do it after you got the pan off. It might be easyer to work with incase you have to drill it out and retap it.
Old Sep 16, 2008 | 06:53 PM
Thanks guy! I am not planning on changing the fluid and filter as of yet, but I will in the near future. Were have you ended up now? Did you make your big move yet?
Old Sep 17, 2008 | 08:34 AM
rxsteven's Avatar
Witch one nitrous or the move back home. Well I havent done either yet I did buy a kit but no bottle yet. I told the boss I want to go home and gave him my 2 week notice. He gave me a GMC dually to drive and a gas card. So I havent drove my truck much lately.
Old Sep 17, 2008 | 08:56 AM
HarderThanRocks's Avatar
Sweet.. I want a gas card..
Old Sep 19, 2008 | 04:19 PM
chevy112488's Avatar
have you checked your owner's manual about checking trans fluid? most have to be checked at operating temperature... and its really not hard to just drop the pan just a little at a time, more in the back than in the front, if your drain plug wont come out... a lot of vehicles now dont even come with drain plugs
Old Sep 19, 2008 | 09:15 PM
DamnYankee's Avatar
I would recommend getting a deeper trans pan (eBay search: 4l60e derale). It doesn't take long to replace and will help the life of your trans by dropping temps.
Old Sep 22, 2008 | 07:56 AM
jcbst12's Avatar
Won't that bracket get in the way of the deeper pan? I could be wrong but I thought it went kind of underneath the pan a little on the passenger side? Well if thats not an issue I think I would rather do that then have an add-on cooler up front.
Old Sep 22, 2008 | 10:36 AM
DamnYankee's Avatar
I would do both. Trans coolers are cheap and an easy install. Beats replacing the trans or rebuilding due to heat-related issues.
Bracket won't be in the way.
Old Sep 22, 2008 | 01:12 PM
That is all good infomration to know for the future. A deeper pan and a trns cooler. I was already planning on the trans cooler.
Damn Yankee do you reside in San Antonio by chance? Or is it a dark kept secret?
