Electric Ignition Switch - '95 Chevy Silverado
Hello, I own a 1995 Chevy Silverado 4x4 Single cab short bed truck. I love it! I've had it for almost 3 years now, has the 5.7 liter engine, with some off-road packages. I have been experiencing troubles trying to start it lately. And even beyond that, sometimes when I'm driving down the road the truck stalls on me. I have replaced the computer, and I'm still experiencing the same problems. I replaced the computer because that is what the code was reading. We took apart the steering wheel column, and found that the pink 'hot' wire was a bit loose going into the Ignition starter wire harness. I was wondering if the Ignition Switch Starter is what I need, or is there an 'Electrical Ignition Switch' that is different from the Ignition Switch starter. Which 1 do I need, and how hard is it to replace?
Thanks, Jason
Thanks, Jason
J- I don't have an answer to you question ..but you will probably be waiting a while for an answer in this part of the forum ...post this on the silverado forum and you will get an answer fairly quick.
Best of luck.
Best of luck.
herlihy775
Sep 7, 2010 10:11 PM
jayes95silverado
Nov 2, 2007 02:43 PM
